This should be my last bit of glassing (not counting the taping of the floor).
The V-bunk area before I bought the boat. ![]() After I pulled the carpet up the gel coat was all crazed out. ![]() I like to make notes where I know I won't forget them. Did some heavy duty sanding. ![]() I wanted to fill the large access holes since I would not need them and I thought they were awkward to get at. Cut up some plastic cardboard and made it tight against the opening. Outside and Inside View. ![]() ![]() The layup was done from the inside. Less fairing to do and a lot less sanding. Different sizes of glass...the first size is the same as opening and then they get larger. ![]() When done it looks like this is the way it should be. ![]() The next part was to lay in some backing cleats for a v bunk filler and to glass in the bow U bolt backer and the front deck lifting ring pad. ![]() ![]() Shoot some primer to see what I have. ![]() ![]() Happy with the results. Now to the major task of putting the floor together. ![]()
Display Modes | |
