Old 08-26-2010, 10:03 AM
Default Re: Outboard motor w/ HIGH hours??
All the compression testers I've used have a check valve that prevents leak back. The needle stops and stays at the uppermost reading and you manually release the pressure. A leakdown tester's indicator is free to show a lower reading as pressure drops.
