Old 09-11-2010, 10:39 PM
grgrmouse grgrmouse is offline
Default Re: I Need A Shrink !
Coffee=Irish...........check
Parka=Down.............check
cam=video..............check
Rain gear=Cabelas......check
Ready whenever rain or shine!
20' Mako 175 'rude
Sacto, CA
looking for a landlocked 23'-25' Seacraft
http://classicmako.com/forum/topic.asp?TOPIC_ID=13979
Old 09-22-2010, 01:48 AM
More weekend warrior work going on. I've had very little time to get anything done as work has me running around putting out small fires here and there 7 days a week. Most of the work I've been able to do is at night so I've been burning the midnight oil lately trying to get things wrapped up. My goal at this point is to get the boat operating so I can do a little Fall fishing in this thing...but well see if that happens.
The outdrive is partially mounted
I ended up salvaging the old bow rail of the other 25 seafari. Rather then spend $1800-2K to have one welded up, I instead spent $125 on some new fittings. I still need to polish it up and finish bolting it down. I like the way it looks and a big thanks goes to Bill for helping me get it on there.
Swim platform is permanently mounted and ladder is installed
Platform for batteries
Hydraulic steering.
At some point I plan on installing a furuno Navnet 3d on this boat and I wanted to get away from mounting it on the dash so I copied Bonefishes idea of a flush mount flip up electronics box.
Cutting out the dash
I'm too cheap to buy teak and it's hard to find here in N. California so I used mahogany and gave it several good coats of cetol.
a rubber gasket sits in a routed out channel
There is enough room to see most of the gauges when sitting at the helm. The important ones will be mounted on top of the gauge panel. When standing up at the helm all of the gauges are visible.
A cam lock helps to keep it sealed from the elements.
The extra rocker switch is for the fuel gauge thanks to Denny for that idea.
A view from in the cabin. I plan on mounting a small flat screen DVD on the two legs of the flip up electronics pod.
My working conditions every night
We took a little day trip to Monterey last weekend. There were tons of boats on the water in the morning fishing close to the beach. I hear they were catching white sea bass! I did not get any pictures of that but here is a couple of the harbor. Perfect day for fishing but we went to the Jazz festival instead.
Old 09-22-2010, 08:41 AM
Truly amazing work there, Strick! I'm impressed with your ingenuity. Can't wait to see some pics when you get her in the water.
Old 09-22-2010, 09:33 AM
SBD SBD is offline
Looking great. The recess setup is very slick and is in harmony with the classy old school boat.
The WSB bite has been insane. Its a once in a lifetime year. You should go, awesome fish and incredible table fare.
Better than jazz???
Old 09-22-2010, 09:52 AM
Bryan A. Bryan A. is offline
Nice dash setup!
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 09-22-2010, 10:50 PM
Better than jazz???
Yes that would be better then Jazz The only white seabass that I ever caught was about 1/3 that size and I caught it by accident...I catch everything by accident usually I would like to go but I need to hook up with someone "In the Know" if you know what I mean. Live or dead squid I hear works good.
Old 09-22-2010, 09:49 PM
Lookin' sweet, Chuck. I'm planning something similar for my helm station, but I want to bring the flip up panel all the way back to where you mounted your switches. Still sorting out where my switches and trim tab controls will go.
When I got my 25, it had the single fuel gauge with a switch for toggling back and forth. I decided to go the other way, with two gauges, so I wouldn't have to remember which tank was on the gauge, which tank was feeding the engine, and if they were the same. I'm afraid I'm getting forgetful in my old age and need all the help I can get.
Dave
Blue Heron Boat Works
Old 09-23-2010, 12:54 AM
I'm planning something similar for my helm station, but I want to bring the flip up panel all the way back to where you mounted your switches. I decided to go the other way, with two gauges, so I wouldn't have to remember which tank was on the gauge,
Bringing the flip up forward would help. You could mount the switches to the left, right or below the wheel or on the vertical area to the left of where the flip up is. Problem there is they might interfere with the entry into the cabin. On the rocker switch forward will be for the front tank and back will be for the rear tank. Remembering which tank the the selector valve is feeding will be my problem
Old 09-23-2010, 09:02 AM
SBD SBD is offline
I have to leave for the Klamath tomorrow to work on my friends fishing show, but if its still going when I get back I'll send you a pm...get one of your boats ready. Its very easy and very fun.
Old 09-23-2010, 09:38 AM
I can't really tell by your pictures...is your Volvo running electronic ignition?
If it's not I would highly recommend putting in a conversion for a couple of hundred.
I did this on one of my inboards and never had any problems trolling or idling. Matter of fact didn't need to change plugs for a very very long time. Always clean burning.
