Old 11-29-2010, 11:48 AM
lost2a6 lost2a6 is offline
Default Re: Mercruiser Woes-What Next?
Be sure to change both of your manifolds, not just the one that is leaking right now. It's pretty much straight forward on swapping your FWC componets over to the new engine. What would be ideal is to have a heat exchanger big enough to cool the manifolds as well, that way you would only be concerned with replaceing the risers when they start to eat away which in the long run would be cheaper. On my Seavette, every thing is FWC for the exception of the risers in which those are made of stainless steel.
Steve B
Old 11-29-2010, 05:12 PM
Steve is right. Stainless is the way to go, if you can. But don't assume that stainless is a panacea.
I have even seen one of those fail from what was apparently electrolysis damage. It was on a Formula 302 with twin Merc 7.4L 440 hp with the "Silent Thunder" stainless exhaust manifold/riser/muffler systems. The stainless exhaust manifold had what looked like a wormhole going from the water jacket out to the outside of the manifold, spraying a fine mist of saltwater over everything. When we tore it down, the inside had several more of those wormhole-looking defects, but none that made it to the outside (or to the interior, either).
Fr. Frank says:
Currently without a SeaCraft
