Old 12-01-2010, 07:57 PM
pelican pelican is offline
Default Re: Taking off outdrive
no need to pull the wheel if it has a rubber hub-freezing temps will never damage it...age and impact will tear it up,cold weather isn't a factor...just be sure to pull the wheel once a season-lube splines and rinstall
side note:
use no grease with mettalic compounds-especially "never sieze" you can create a galvanic reaction...
