Old 02-04-2011, 12:04 PM
SOS SOS is offline
Default Re: rebuilding/repowering a 20' center console
A 175 would be my choice if I could pick one. The 140 works well and sips gas but I'd like more power to plane easier when i'm fishing with a heavy load. Topping out at 40mph is ok, but i wouldnt mind hitting 50.
175 Zuke or 175 Etec would be my choices.
Good Luck and post us some pics!
SOS
Old 02-04-2011, 02:29 PM
jfc6866 jfc6866 is offline
Thanks, will post some pics this weekend.
Old 02-04-2011, 02:51 PM
One other thought, Don Herman said If I put a single on I need 30" shaft and twins 25" shaft. In just looking if I drop below 200hp it doesn't seem any of the engines are offered with 30" shaft, any thoughts?
Old 02-04-2011, 04:40 PM
5" extensions kits are readily available for just about any motor 75hp and above except most 75-115 hp 4-stroke Yammies and all Suzuki . But I understand the Yammie shafts extensions will be available later this year.
Go to Bay Manufacturing
I know of nothing available for any Suzuki.
Fr. Frank says:
Currently without a SeaCraft
Old 02-07-2011, 09:59 AM
I emailed Bay Mfg. and while they don't have anything now, they advised that they were working on it. They couldn't say how long it would be, though. [img]/forum/images/graemlins/tongue.gif[/img]
Old 02-04-2011, 05:03 PM
I would double check that with Don. Those numbers apply on a 23' but not so sure on a 20'
Maybe Bushwacker (HermCo bracket, Etec 150) will chime in again. I think Denny's Etec has 25" shaft...
Old 02-04-2011, 05:20 PM
I had double checked with Don before I bought the bracket, he had made this one special as the width was less than the one for the 23'.
As for the engine extension kits, I didn't know they were available, will check into that. I'm leaning toward yamaha anyway as I've had good luck with the 3 yamaha's I've had before.
Thanks,
John
