Old 02-27-2011, 01:35 AM
Default Re: Kicker power versus weight on a Master Angler 20
Connor's right - it's all about torque. Years ago Chrysler and Evinrude used to make "sail drive" models of about 6 hp similar to his Yamaha with lots of gear reduction and big slow turning props. Too bad they don't still make the old British Seagull. Very simple (some would say primitive) with exposed flywheel and gas tank (looked like a 1930's vintage outboard), no recoil starter, but very light (maybe 30 lbs) with LOTS of torque. Lots of brass and nickle and virtually indestructible. My neighbor had a 5 hp model, with a 5 blade prop about 10" diameter with about a 5" diameter hub and lots of gear reduction. With that thing on his dingy, he could TOW his 20 TON 42' Wheeler sedan cruiser! But I'm sure it wouldn't pass emissions laws and OSHA would go nuts with an exposed flywheel and starter rope!
Old 02-27-2011, 02:59 AM
Based on the comments, I searched and these are available at defender.
http://www.tohatsu.com/outboards/6_4st_spec.html
A Tohatsu SailPro.
Maybe that would work.
Old 02-27-2011, 10:55 PM
So, just to complicate the issue, don't forget to factor in the hydrodynamics of the hull at displacement speed. Most of what I have to say here is from Dave Gerr's "The Nature Of Boats". But I've probably got some of it wrong because I loaned the book to someone who didn't retern it, so I can't check.
Every boat has a "hull speed", the most efficient speed for the hull to travel when it's in displacement mode. Hull speed is mostly determined by waterline length. When a boat moves in displacement mode it pushes a bow wave in front of it and drags a stern wave along behind it. This basically sets up a standing wave with a wavelength roughly the same as the waterline length of the boat.
The speed that waves move through water depends on their wavelength. Waves with long wavelengths travel faster than waves with short wavelengths. A short hull sets up a short standing wave that moves slowly. A longer boat sets up a longer standing wave that moves faster.
Hull speed is the speed at which the hull is in harmony with the speed its standing wave wants to travel. If you try to push the hull faster than hull speed, it tries to climb the bow wave and the bow of the boat rises. Because the boat is now trying to run up hill, it takes a lot more thrust to maintain this faster speed. Given enough thrust, the hull climbs over the bow wave and is then traveling at planing speeds.
So, in a nutshell, the kicker best suited for the boat is one that pushes it at hull speed while it is running at its most efficient RPM. Unfortunately, I have no idea what this is for a Seacraft 20.
Dave
Blue Heron Boat Works
Old 02-27-2011, 11:32 PM
Having owned a 20 MA with a kicker (8hp Yamaha four stroke and then a 7.5hp Merc) and now an 18 with a 8hp Honda kicker, your problem is going to be the 20" transom. Both my 18 and 20ma had 25" transoms and I would take waves over transom. My motor is a lightweight 365lb Merc blackmax too.
Old 03-02-2011, 02:23 PM
thats my point - the boat can't handle 500+ lbs plus somebody sitting back there driving - buy a good VHF radio and a Sea Tow membership or you need a bigger boat
Old 03-02-2011, 06:31 PM
cdavisdb cdavisdb is offline
I'm not familiar with the Tohatsu, but the pic doesn't look like a big prop. There is no substitute for surface area in applying power to the water at slow speeds; be a little skeptical. I'd try to find somebody using one on a boat similar to yours.
Connor
Old 03-04-2011, 05:28 PM
Don't forget flippers and water wings. If you break down in Buzzards Bay in the SW afternoon wind with a 20" transom and a heavy motor . . . You'll be calling the coast guard before seatow arrives.
Old 03-04-2011, 10:20 PM
Exactly.
So for the moment I need a light kicker. Ideally with remote steering
