Compare that set up to this website: http://www.epoxyproducts.com/ - I dare you to find pricing info on there, let alone the products you actually want. - That said, I would much prefer to navigate a home built website and get a super high quality epoxy product for $45, then waxed west systems stuff for $80. Didn't mean to suggest that west marine has anything to do with west systems, beyond the fact that the west systems fixture is usually found in west marine stores. Never mind that west marine loves to mark up products because they are "marine grade." Quote:
With regard to the poly on wood, that's a different point, but same idea. Roughing up allows for a better mechanical bond. Molecular water does go through straight poly, but that's why you prime or bilge coat. And make sure any hole you drill get sealed up properly. Here are some epoxy on ply project that you claim will sink within a year because they didn't use the fancy core stuff: http://www.fishyfish.com/boards/index.php?topic=259.0 http://www.fishyfish.com/boards/index.php?topic=956.45 (I'm joking... I know you don't think they will sink. For a while at least!) And I think you are wrong about the cure times effecting wicking... epoxy is simply based on different solvents that wick better into wood. If you have ever used CPES or GitRot, those two products shift the solvents way down the spectrum to the point where they are as thin as gin or rum. In other words, even if poly and epoxy cured at the exact same rate, epoxy wets out much much better into wood. THAT's on the epoxy products site! Quote:
Lowes does not sell "marine" grade ply, but the arauco is void free (for the most part) and most A/C ply is good enough for decades of use in saltwater skiffs. Apparently on seacrafts it's important to vent the bilge to increase the longevity, someone should start a thread on that topic. Maybe do a poll or something. Completely agree with you that the new stuff, in theory, seems way better. Sorry to suggest that you were pushing for it (even though I still think you are!). I think part of the answer is that wood works, and it's not clear to me at least, that the composites are THAT much better. Better yes. A jones brother is better than parker. But how much better in dollars? In terms of the time it takes to either drive to some place, or risk buying something unknown that is expensive, and that a bunch of sales guys at various boat shows seem to keep hawking very aggressively. I called it "your stuff" because the guy who posted earlier on this page used ply, and you suggested that he use something else. Ok fine, technically, you asked why he didn't use this other stuff. I wrote a reply as to why I am still using ply, and you sort of got defensive. Which reminds me... the doghouses/pilot houses look awesome. Very burly, and just enough curves to give em some class. Nat's is nice, I think, because the curves keep it from looking like a giant box. Can't wait to see what shrimp has been up to. |
