I have come to the realization I need to pull mine off and re-seal them. Am I correct in assuming Epifanes dries to a super hard (almost resin like) finish? I dont want an oil, and there is already a coating of something on there that is flaking off. I have started stripping them down, is there a better way than sanding?
Epifanes does harden like a resin, but seems to be one of the best varnish/sealers out there. There is a tool for stripping varnish/paint and if previous application is thick it is def. the quickest. Eventually, sanding is a must. I have one or two more sands then I am applying the clear coat.
Ok I am starting to sand my rails, and get ready for coating them. Heres a question for you guys. After I sand them down and get the old varnish off, do I seal them to the hull with 5200 first or lay on the Epifanes first.
In my mind I want the wood to bond to the glass, then seal the wood with varnish. Or should I go the other way around and get a better 'line' with the 5200 sealant? Should I be using 4200 instead of 5200?
I would seal the whole part first then attach to boat, this way if water intrudes it does not wick from the backside. 5200 is for permanent imho, 4200 if you ever want to take it off and do it again in the future.
I never actually pulled them off the boat. On closer inspection there is about 2ft of sealant missing, and they dont 'wiggle' at all. My plan is to dig out the old sealant and apply new along with sanding and varnish. Will I have a problem with the 4200 pulling away from new varnish? It just seams like it wouldn't adhere well enough.
