Hi all;
I'm looking at pulling the cap off the 1965 bowrider, to remove and replce old rotted wood under the gunwales, transom cap, and front sitting area. Looks like the cap is glassed on to the hull. Any advice? Have any of you removed the cap on the bowrider? Steve
"why are you buying such an old boat?" 1974 SeaFari V6 i/o, 1965 Bowrider 19' i/o, 1975 Sceptre 23' i/o, WS Tarpon and Hobie kayaks, 12' Starcraft tin boat |
I got a bobcat!
Wildman, thought you used your fingernails?
Steve, but he may be right. That's got to be difficult. Hope you guys are well....may be launching the 26 for maiden voyage tomorrow pm. Steve |
Steve,
Harbor Freight has a cheap air cut off wheel that would be ideal... It has worked well for me in tight places.. Good Luck, Ken
See ya, Ken © |
Yepper.....as always, Ken is right! While you are there might as well get the angled grinder, some 2" or 3" 36 grit "Roloc" sanding disc and lots of sandpaper. You will be needing them.
![]() http://www.harborfreight.com/air-too...der-32046.html |
Any way you cut it ![]()
Before you buying any power tools Steve, I own an angle grinder.
--------- 1977 Seacraft, Armstrong Bracket 275(chipped 250!) Verado Merc Rev 4 17P |
I have 4-5 of them in various flavors also
![]() Steve I only use my finger nails on the 'good' jobs. ![]() Finding a picture (or somebody who has taken the floor out) of one of those little boats, would be invaluable for knowing how much Hull&deck putty is under there and where its located. But then again, you might get lucky and like my boat all those joints had cracks and after you cut the rivets it will just lift out.
You might try contacting 65bowrider. She redid hers and might be able to enlighten you. Don't know how deep she had to go with hers, though.
I might try to replace the bad wood with the cap in place; looks like a tough job getting that cap off. And it looks like it is riveted to the hull too, through the rub rail. I'm going to try cutting though a length of the glass tabbing and see how that goes; I'll report back.
Steve
