Old 05-29-2011, 09:15 AM
CDLongJr CDLongJr is offline
Default Re: Can't get lower units off
Ok, repairs made, now it won't go back together. Lacks several inches from going up. I turn the prop, thinking the driveshaft splines aren't lined up, but when I turn the prop, the driveshaft doesn't turn, (althought I don't know how or why they would have turned).
The Ole Fart
1986 23' Walkaround w/cuddy, Twin 135s
Old 05-30-2011, 12:03 PM
did you remove it when it was in gear??
Old 05-30-2011, 02:32 PM
put vice grips on the shift shaft (on the lower unit) and shift the lower . . . clockwise is forward, counter clockwise is reverse. Once lower unit in gear . . . just make sure it matches your the throttle position (forward or reverse) Drive shaft spins clockwise always.
