Old 06-21-2011, 08:55 PM
Default Re: Help with water in bilge
I have a 2005 20' Seacraft and am getting a little water in the bilge, not much but any amount is more than i want.
Do you have a deck plate or other bilge access in the motor well? If so, that would be a possible source. That being said, it's not unusual for an outboard boat to get small amounts of water in the bilge. Water on the deck will find a void in the sealant around a hatch. Bilge vents will allow a little water in. The hole where the engine wiring harness and steering cable/hoses pass through can allow water in. Unless your automatic bilge pump (you have one, right?) is kicking on more than once per hour, I wouldn't sweat it.
Dave
Blue Heron Boat Works
