Old 06-26-2011, 03:42 PM
Default Re: 20 MA project continues
I HATE SANDING!!!!!!!
Oh let me tell you how I really feel
Old 06-26-2011, 04:07 PM
I know what your talking about my hands are killing me only a couple hundred more hours to go
1979 Septer I/O no power Sold
Old 09-11-2011, 05:37 PM
Well after no activity on the boat since we got the place in the Keys bad weather and just plain lazy I am going to go at it again ....So here's were I'm at
I have the Console and all the hatches ready for paint, I have the outside and bottom of the hull sanded and ready to finish primer. Now the inside I have most sanded but plan to go over the whole inside incase I missed some place, but before I need to finish these 2 spots
The rear hads a soft spot so I took out the rotted wood and relace it and I did save the skin to replace it back
[image][/image]
The front deck also had a larger soft spot here I took out the rotten wood and replace it with 4x4 pieces covered with glass.
This has taken me a lot longer than what I thought
[image][/image]
Plan it to attack these 2 areas this week and continue to sand (Did I tell you I HATE SANDING!!!)
and hopefully start the paint sometime next week.
NOw after the glass what would be the best filler to make it as smooth as possible. Although both will be an area that the non skid may help hide my amature results
Now I do have some damage to the 2 channels that go somewhat in the middle of the deck from the console back and I was thinking it may be easier to not try to make it look original and glass it over...Opinions?
Any contructive critique is encoraged!!!
Old 09-14-2011, 08:39 PM
Took care of floor in the rear section Pics to follow as its dark
I ground down the underneath part of the skin along with all around the skin and flooring so I can glass it in tomorrow. I first prepared some thickend resin to a milk shake like consistency and then placed the skin on top I also placed 3 concrete blocks on top to hold it down. Tommorrow I will glass it in and day after sand down even with the surrounding floor. On the weekend I hope to tackle the larger part in the front.
Got to get it done!!!!
Old 09-15-2011, 06:14 PM
Took off the concrete blocks and it came out fairly well.
I thought I had more resin and mat but was wrong so off to the store tomorrow.
I need to grind down some parts and I'm probably going to take off the rest of the gelcoat on the skin I put back down
[image][/image]
Old 09-15-2011, 07:12 PM
I must be doing something right no one has commented on my amature work
Old 09-16-2011, 08:40 AM
You have learned well, weedhopper!
Old 09-17-2011, 09:33 AM
red20 red20 is offline
Every Pro was an amateur at one time.
