I am sure my boat will ride better once the bracket is installed. BigMike
www.bigmikeslures.com |
hope it will ride better mike. it just seems to me more flotation would make the bow dip foward when baot is still in the water. thats the last thing i want more standing water in the cockpit.maybe i shuold buy that 27' seamaster what a fn boat!
I have been looking around for measurements on a design for a bracket similar to the single engine Hermco.
does anyone have the measurements by chance because i have read so many different idea's on how much higher the motor should be mounted once the bracket/pod is installed.I will have a 75-90hp long shaft mounted when done so the normal mounting would be at 20inch but i am confused as to what height it should be once the pod is mounted. i have been toying with the idea of building mine to extend 60cm/23inch from the existing transom so i can get some deck space and add some extra flotation with the added pod. thanks 666 |
