So, I've been doing some stuff in the shop. I bonded the live well tub to the outer box and started on the plumbing: ![]() My fuel tank hatch had a little flex in it. It wasn't soft, but I felt like it had a pretty big span for a hatch with only a 1/2" core, so I added some more thickness: ![]() In one of my earlier posts, I mentioned that I'm making my cooler/compartment hatches in two pieces with a foam core so they will have a finished surface inside and out. It's a lot more work, but I like the results. Last weekend, I layed up the inner liners for the fish box hatches and the flip up thingy above the cabin door. I used the usual process; make a mold with masonite and spruce, coat the mold with clear lacquer, fillet the inside corners with modelling clay, and spray with PVA mold release (Partall Film #10): ![]() Sprayed with gelcoat: ![]() After the layup: ![]() And popped from the molds: ![]() ![]() Here's the flip up thingy trial fit: ![]() And a trial fit of the liners for the fish box hatches: ![]() ![]() ![]() ![]() Unfortunately, I screwed up on the dimensions for the hatch liners. I made the molds with about 1/8" of taper from the top to the bottom, but when I laid out the molds, I used the top dimension on the bottom. The end result was that my liners were 1/8" too big and a pretty snug fit. It didn't take long to figure out that I wouldn't be able to sand the mating surfaces enough to make them fit, so I bit the bullet and shrunk them both by an eighth inch. I did this by making a cut down the center of both panels on my table saw. The material removed by the saw kerf was just right. I ground a bevel on both sides of the cut and rejoined them with masking tape to hold them in place while I laminated the seam with a couple layers of 10 oz. cloth: ![]() ![]() And back together: ![]() And another trial fit: ![]() After reducing the width of both panels by an eighth inch, they fit just right in that dimension. But I will need to take an eighth inch out of the length dimension of one of the panels to finish the tweak. And that's got my thread mostly up to date. Next, I'll be fitting the hatches with hinges and then coring them. I'm using T nuts imbeded inside the hatches so you won't see a fastener on the inside. It's a pain to do, but leaves a clean look inside the hatches. Dave
