  #30
Old 09-14-2011, 08:24 PM
Default Re: '73 23' Rework & boat porn :)
The wiring works All lights, pumps, etc. work. I moved oil tank and batteries forward and still have ~ 1 foot storage in front. The hanging wire will be pulled back through for under electronics box red/white light. I went with Blue Sea switch/ACR, external box,fuse and switch panels. I ran 1/0 cables to post in the rear. The small post is the Yamaha aux charging lead which I'm not using. I would like to give credit to www.genuinedealz.com on their wiring products, ability to follow fabrication instructions,pricing, and turn around time; Those guys are FAST!! I built the switch/key panel from 3/4" white starboard and the drip-lip from 1/4". The fuse panel cover is off in these pics. The Yamaha started right up! So I need to finish baitwell plumbing, mount leaning post,install Bay Mfg. engine extension,new water pump, rub rail (at some point) and tidy up a bit.
