In my well is a 6"x12"
opening acces to bildge with a clear plexi cover that slip I to a aluminum track. There are no screw boles in the plexi but there are in the Fiberglasas around the hole. Are all 20SF,s this way or perhaps a past owners doing I'm just a bit concerned with seawater comming in the well drain holes and going into the bildge ![]() |
I have a similar hatch on my '83 20. Must be a Seacraft Industries thing. You're right to be concerned, it leaks like a sieve. I usually keep plugs in the motor well drains. And I have redundant bilge pumps.
Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
If it leaks fix the source rather than compensate for it. It should replaced with a hatch that seals much better, lots of them avaiable but the transon plugs should not be plugged because of it. They provide a place for water to exit the boat in case you take one over the bow and need to be open.
I have a Pyi Hi set it a plexi plate that I have to seal and want to change it to a hatch so I get a bigger access area quicker than pulling the plexi plate up.
87' 20SF. This is the best picture i could find. Its a round access hatch. Its on threads and screws tight. Its nice knowing the access plate is screwed in and secure but there isnt much access to the bilge.
![]() And yes i know its really dirty. That picture is from before i bought it. |
Same thing I have but mine is set in a plexi piece that allows better access - I want to re-do mine with a hatch so i don't have to pull the plexi to get more room. They come in all sizes, West has them as well, its a pain doing anything in there thru the Py Hi
Mike slips into a track at the transome a d it holds it up slightly. I could screw it down and seal it but then I ciould not access the pumps fast if I had to.I'd like to see a hat h over it but the size is only at a max 9" front to back I've only seen 91/2" and then the hight of the hatch may be a ploblem if it was installed up againstthe transome. 8" x 12" would be good
Maybe just run a bead of silcone around the back, shouldn't be in it that often
Let me know if you find a hatch that will fit.
Mine is an MA and has alot more room than 9-1/2'' but I will look in my travels, because I am going to do it - I just want to pull the lever and have access.
![]() Quote:
http://www.beckson.com/hatches.html |
Display Modes | |
