Old 11-13-2011, 12:07 PM
Finster Finster is offline
Ya mine has the original alpha I gen I with a ford 351w and I like it a lot. Didn't think I would like it as much as I do. Even the raised motor box makes a nice casting platform. Though it does seem to have an electrolysis problem, but I just change the zink every month or so.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 11-13-2011, 05:18 PM
pelican pelican is offline
dumb question - does the "trim indicator" work ?
Old 11-13-2011, 06:07 PM
Don't have one. Typically they never last long anyway when repleced.
'76 23 SC CC I/O
Old 11-13-2011, 06:57 PM
center consoles - seacraft center consoles - they've got a flush fwd deck - this is where you battle a big fish from this is how it's done...
Yep ! That'sa right
Old 11-13-2011, 07:06 PM
Originally Posted by capt chuck View Post
yep ! That'sa right :d
nice capt !!!
Old 11-13-2011, 07:41 PM
oldfielder oldfielder is offline
Pelican-
I suggested the flusher for the bravo because my boat has the same cooling setup and with the boAt on a trailer i now have a good system to run it in the driveway.
I agree about the block flushing not accomplishing much.
I've been down the manifold failure route-aint no fun. Was able to save the motor though with some quick action.
Old 11-13-2011, 07:54 PM
My 350 Mag MPI has closed cooling (including the manifolds) and came from the factory with a quick disconnect for running it on the hose.
Pelican
What is the most common cause of water ingestion, manifold failure? Do the manifolds rust out from the water jacket side, or from the exhaust passage side? Or is it riser gasket failure?
Dave
Blue Heron Boat Works
Old 11-23-2011, 12:27 PM
bigeasy1 bigeasy1 is offline
Great info.
I also have a stern drive on my Tsunami,and also on my last boat.The whole sterndrive bashing is kind of like the bashing Bayliner took.Most of it is done by people who never owned either a stern drive,or a Bayliner.
No doubt that in salt water stern drives require more maintenance,and proper care needs to be given to the drive.Because of the salt corrosion problems parts may need to be replaced more often,and you can't tilt the drive completely out of the water like an outboard.
I'm ten years into pretty hard use with sterndrives,and can count on one hand,any problems that required any serious work.
Like anything else you have to maintain them,bellows need to be inspected and changed periodically,gimball bearings need to be greased properly,as well as the u-joints.Exhaust manifolds need to be changed occassionally,especially in salt water.In fresh water they last for years and years.
I know that most of the members on this site are salt water boaters,but on the great lakes where guys like me and Floorboy fish,I/O's(and inboards) are much more common.I like the big high transom when we're fishing in snotty stuff and the waves are rolling up the rear.I also like the open transom for netting fish(we only troll),nothing in the way.
I also like the fact that I can do almost all the work myself,as it's a simple 350 GM engine.I don't have to worry about a computer or printed circuit crapping out and not being able to fix it myself.
Even the drive doesn't require a rocket scientist to work on it,and even if it blows up,companies like SEI make great good quality after market drives for cheap money.
I guess if I was fishing the salt,and I had to decide on a power package,I'd go with outboard power.But,I wouldn't be scared off from going with a fresh water cooled I/O.
I can't even begin to imagine what it costs to fix a modern four stroke outboard,never mind trying to fix it myself.I shiver just looking at it when the cover is off.They are a marvel of engineering and nice,but way beyond my skills.
Both have their pros and cons.
All this,just for a boat ride
Old 11-13-2011, 05:31 PM
center consoles - seacraft center consoles - they've got a flush fwd deck - this is where you battle a big fish from - the engine box isn't a factor - you fight the fish from the bow - fish "pulls" the boat,plus,whoever's on the helm,you can see what's going on,to follow the fish - the boat handles a little easier from the "pointy" end...
Old 11-13-2011, 05:54 PM
stern drives - gas engines:
the smartest move you can make,is to pull the plugs and perform a compression test,anually.i normally do this at time of winterization.
run the engine,to normal operating temp,and pull the plugs - take a long look at the plugs - you're looking for either "rust stains",or a plug that's "snow white" - this is an indication,that cylinder's burning water - this shows up,way before any water is noted in the oil.mositure rises to the highest point - get in the habit of looking at the "breather hoses",from the valve covers - look for steam - this is another indication,the engine's burning water.a rusted,salt covered interior of the distributor is another - again,all due to moisture rising...
perform a compression test - what you're looking for is "uniformity",each cylinder should be within 10% of each other...
now,if you're compression is low,on a cylinder - odds are,it's caused by,that cylinder ingesting sea water,via the exhaust valve - end result a runsted valve,that has lost it's concentricity - it's not seating properly - this can be verified by a "leak down" test,with compressed air...
get in the habit of doing this,like i stated,anually
exhaust systems are the weak link...
take a look at these pictures - this is a 5.7 merc engine,it suffered an early death,due to it's exhaust system - normally,these engines,when they hydro lock - the small high torque starter,it will break the block - right where it mounts - this one,it didn't,it bent 2 rods - engine was replaced with a new 5.7 mpi merc magnum...at my shop - we do not use "remans",long blocks,short blocks,or offer rebuilds of gas engine,like these - it's repalced with new,complete,drop in engines,or the job's not done...
as you can see in the pictures,some one,used a silicone sealer on the riser gaskets - bad move - very bad...
