#31
Since the subject came up recently, I've got a question for the experienced stern drive guys. I disassembled my Bravo transom assembly this evening. It was apparent that the seal on the upper swivel pin was bad. The steering arm and swivel pin were pretty badly rusted. I intend to replace both.
So my question is whether I should go with the stock swivel pin or get a stainless one. I'm concerned that using stainless could shift the point of corrosion from the pin to the aluminum gimble ring. If that's the case, next time around I would be replacing a gimble ring instead of a swivel pin.But what do I know? The lower swivel pin is stainless, so maybe it's a non-issue. Anyone got experience using the stainless upper swivel pin on a salt water transom assembly? Thanks, Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
#32
![]() Quote:
it's best not to "disturb",the original paint on the drive,the trim cylinders and the transom assembly - this can and will allow corrosion to get a "foothold",it also leads to the original paint popping off - which will lead to the entire drive needing to be stripped,chemically etch primed and refinished - the only way to repair that situation permenantly...
do not let common sense get in your way |
#33
![]() Quote:
#34
Pelican,
I will defer to your judgement - you definitely seem to have a lot more experience with mercruiser I/O's. I am very happy with the condition of my set-up... Just not the work each spring to get it there... Wish I had a boat lift ! |
#35
![]() Quote:
#36
I have a question in regards to the alpha one gen 2... I have changed my ujoints and Gimbal bearing due to a knocking. It doesn't happen at full trim or at any turn angles, just when it's in gear. The previous owner said it has been that way for a couple years. It's not a severe banging, just a clicking when the boat is placed in gear. Any ideas?
Thank you in advance. |
#37
71 Seafari, Mercruiser 140. Current motor block indicates it was manufactured in 1986/7, but has all 1971 electrical and ignition stuff. Original transom group and original M/R outdrive. Installed all new seals last fall, all new bellows, new lower cable, new hoses, new manifold and new exhaust riser/elbow.
We live in Florida, so "winterizing" is unnecessary. HOWEVER, after many years in the marine industry, I have an annual "maintenance list" for a sterndrive. JANUARY 1 Remove drive Change water pump impeller, inspect pump housing and wear plate. Remove propeller Inspect seals, bellows, u-joint, drive shaft Lubricate, lubricate, lubricate New outdrive gaskets and o-rings (never re-use) Change Lower unit oil. Clean and re-grease prop shaft I would say that with proper flushing, raw water cooled manifold, risers/elbows, and t-stat housings are good for 6-7 years. But ya' gotta flush the motor for a period of time AFTER it gets to full operating temperature. Salt-away isn't enough, nor is 5 minutes running at idle with a cool motor. But eventually, these pieces WILL need to be replaced
Display Modes | |
