Old 12-14-2011, 01:51 AM
Originally Posted by 6buoys View Post
strick i seen yuo used foam in your bracket . first what kind and second is there an advantage over ply other than weight
I used corecell. The no rot thing with the foam is the biggest advantage I guess. Corecell has good compression strength but not as good as plywood. The set back on the yellow bracket is 22.5" and if I remember right I built it I could be able to put a Suzuki 140 on it and be able to tilt it up all the way once the Yamaha dies.
