Glass laminate isn't ideal for drill and tap for machine screw threads but it can be done. Just make sure you goop things up real well with 5200. And you might want to back it up with a nut on the outside. Dave
Got done trimming up the flange and put a radius on the corners. Also snapped a picture with the pumps just sitting in the box.
The wires will exit the rear and be sealed by blue sea cable grommets. I am going to try the method Dave mentioned for fastening the pumps to the floor of the box. After doing some reading on west system's website I was thinking of using thickened epoxy to seal everything up. Thought this might bond everything together well but would also be paintable so I could fillet the amount that squeezed out and make it look like there was no joint. |
