Old 01-22-2012, 12:43 PM
bly bly is offline
Default Thanks guys for the good words.
Strick picture you posted of that lefty kreh is beauty and simplicity to my eyes. Its like a disease in boats we all try to bolt on as much extra as we can. It seems like a disease that boaters can't not, not contract? My self included. Oh here is the bracket finally in place waiting for me to glass in all the seams with vinyl ester resin and 1708.
Weight wise I would guess under 70 lbs if not 60 lbs.
I scribed and fitted it from my glassed doubled up penske stringers to where they meet the cored transom bracket at the engine point. All light and stiff.
The worst part is having to glass inside the bracket on my belly. But there is nothing else stronger and more failure proof as the way I been doing these.
The transom was so bad on this boat it had cracks into the bottom on that pad that someone badly repaired before. I had to grind and re glass the pad about 10 inches forward and then re fair.. The bracket pad is just a bit wider then the bottom pad but looks so good that I can't believe I have seen no one else do it?
Old 01-22-2012, 07:57 PM
Makokeith Makokeith is offline
Looking really good!!! PLEASE try to post up some pics of where the stringers and the bracket come together. Are you going to close the bracket in from the bilge area?
This thread is making me think about building my own bracket for my formula 233.
Old 01-22-2012, 08:52 PM
bly bly is offline
Default I have done a couple of 233 formulas this way. each stringer is made up of
2 pieces of 1/2 inch penske 20 that meet into the existing stringers at two different places or point in the same stringer system there is also a layer of Biaxial glass between the two layers. I think it makes the system fool proof. instead of one 3/4 or one 1 inch penske. It all gets glassed to the hull and the existing stringers and then to the bracket. along with the New transom all glassed to the new stringers the hull and the bracket. Then when the floor goes in the boat with bracket will probably will have No flex possible compared to most bolted on brackets. Way less weight. No chance of caulking changing and allowing water to enter without knowing. It all stays open so that you can reach the bottom bolts to the OB mount. I hope that answers all the questions and here is the best pictures I have of what you asked for. I will try to take some more tomorrow?
Old 02-18-2012, 10:14 AM
bly bly is offline
Default Getting a little more done. console with coffin . tank in. floor is ready to go in.
for good.
beginning of a teak helm pod for the 20
Old 02-18-2012, 01:02 PM
WildBill WildBill is offline
Bly; That helm console is "SWEET". Is it teak or a plywood?
Old 02-18-2012, 04:58 PM
GCC GCC is offline
Lookin sweet Bly! I cant wait to see this one come together.....
