Old 01-29-2012, 08:49 AM
Originally Posted by Iceboy149 View Post
Can anyone point me in the best prop for this scenerio.... I believe I have a stock aluminum prop right now and get about 5000rpms until she starts beeping the low oil warning horn. Wondering what sort of props I should look at. Think the fastest I ever went with a GPS was 43mph. I feel like there's more I should get out of it. Before I go into researching props I'm sure someone might have had this setup before and knows more than I do.
Thanks so much for any advice! The motor is also a counter rotation that I picked up from an old grady white pair....it was cheaper than the other one....was working on a budget.
Iceboy
19P viper . . . make sure cavitation plate is about 1.5" - 2" above the bottom of your hull. too low and you lose a LOT off speed. Too high and you'll blow out around the hard turns.
