![]() Quote:
dissapearing zincs: a common cause is the trim sender - wires are broken... another common cause is wet wiring in the boat itself... dumb question: you're stating the cavitation zinc - what about the trim cyclinder zincs ? the zinc on the transom assembly ? these zincs burning up quickly ? trim tabs ? zincs on them ? stainless steel prop ? when the boat's in the water,drive tilted up - are ther any small white powdery deposits apparent on the drive ? the true test is with a special plug in metal - on end of a DVOM is connected to the metal,it's dropped on the side in the water,the other lead on the DVOM is connected to ground - voltage is read... not sure about the zinc coated bannana hammock ? "electrolysis" - it's hair removal...
do not let common sense get in your way |
Display Modes | |
