Old 02-05-2012, 12:48 AM
Congratulations on doing some through research hiliner! Those numbers quoted in Mr. Moesly's patent are for the very first SeaCraft, the Moesly 21 (http://moeslyseacraft.com/SC21Brochure.aspx). On the 20' hull, I believe the deadrise on the inner panel is closer to about 18 degrees, although the numbers for the center and outer panels are about the same. I believe Big Shrimpin previously posted the exact numbers for the 20' hull on here some time ago. The 16 degree deadrise number quoted in the brochures is the average at the transom, measured from center of keel to the chine. There is another unique feature on the 19 & 20' hulls . . . if you sight along the chine from the front, you'll notice that there is a slight wedge shape to the outer panel (it slopes down at the back), which I suspect helps the boat get on plane at low speeds. As mentioned in the patent, a deep-V hull lifts further out of the water as speed increases, and I believe that outer panel is almost completely out of the water by the time you get up to about 40-45 mph! That outer panel wedge may be there in all the other hulls too, but I've never looked for it.
I believe the aeration created by the vertical steps (Click on the link in my signature to see a good photo of this) is the key to the soft ride and low drag of all the SeaCraft hulls. When I showed that photo to Mr. Moesly, he said that back in the early 60's, they spent HOURS at Lake X with a 21 trying to get a shot like that! A good buddy of mine that's a great photographer managed to get that one and a few others off Key Largo with Skip driving Carla's Bowrider, which made a great camera boat!
The vertical steps are much taller on the 21 than any of the subsequent models. I've ridden in the 18, 19 Bowrider, 20, 21, and 23' hulls, and IMHO the Moesly 21 is the best riding one of the bunch. Not surprising, since Mr. Moesly raced it in very rough conditions in the offshore powerboat races in the 1960's, totally dominating the outboard class, even beating some of the bigger inboards with 5X the power! If you look at the front view of Island Trader's 21 that he posted recently with the windshield mock-up, I think you'll get a feel for why it rides so well in big seas!
Haven't ridden in the Seafari 25, but I'd think it's ride is probably very close to the 21, since the hull lines up front are very similar. Naval architect and CSC member Big Fluke has tested a Seafari 25 extensively in big seas off Hawaii for his company, and he said it's "the most seakindly small boat we've ever tested!" They all ride great for their size, however, so do yourself a favor and find a CSC member near you and go for a ride! You will not be disappointed! Denny
Thanks Bushwacker, And that photo is a great shot. I'm jelous, haven'y riden in a Seacraft of any size "YET" Maybe this summer i know a guy that has a I/O 23 I think it's a Tsunami or Sceptre. If it out rides a Seabird, I hears they ride good as well. how does the 23 SC compare to a 233 Formula? Anyone compared these two? I might make it to FL. next winter, maybe catch a ride in one there too. After readind a post here on the 20 Sceptre of which i found one, I'm going to pass on it and wait for a 23 Seafari, I Hope. just affraid if i pass on the 20'er i'll never own one. Thanks for the info, good stuff. Are there any Moesly 21s around? Oh Island Trader has one? I'll check his out too.
