Old 02-05-2012, 05:00 PM
skippertee skippertee is offline
In our research we found nothing to restrict the size of the transom. I understand that 23 and 25 foot boats have been done.
Old 02-07-2012, 12:57 AM
I measured mine into the corners and down to the bottom of the center - 20" - would I just dig out the rest with the chisel??
Old 02-07-2012, 07:22 AM
Yep ... Then use a shop vac to suck up the pieces.
Old 02-07-2012, 02:29 PM
Hey Dixon......the more rotten the wood the easier to remove!!! I poured my transom and it's ALL in the preperation, the pouring is easy.
Old 02-08-2012, 12:36 PM
csurf csurf is offline
There is a local guide in my area who rebuilt his 22 Mako and used Seacast for the transom. He did a great job documenting the entire project including video. Here is the link to the page with a couple of videos hogging out the transom.
Enjoy!
http://skimmer.smugmug.com/Boat-Main...33412_RB3Zrz/4
http://skimmer.smugmug.com/Boat-Main...33412_RB3Zrz/5
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 02-11-2012, 01:35 AM
ChampionShip ChampionShip is offline
Is there any way to funnel that stuff to the bottom to kind of 'bottom fill' it maybe take care of some of the air bubbles? Thinking that might be the route on my Cruisers?
Old 03-06-2012, 10:40 AM
sidelock sidelock is offline
Originally Posted by skippertee View Post
Mr Moesly was impressed with the these new products, he they were out when he was building. Dog, we just juted the seacast and it pretty well moved into the corners and around the spacers. fg1, I noticed a very blush. I put the caps back on, so there is little seacast exposed, but washed areas and have wiped transom with interlux 202 and acetone.
Can seacast be used to redo a 20" transom and raise it to 25" ? Will the styrene blush cause bonding issues in the exposed 5" of seacast resulting from raising the transom ?
Old 03-06-2012, 11:55 AM
Enjoy!
Take a look at the links above. Before they poured the transom they created a mold for a modified notch. I guess they figured it would be safer if they raised the surrounding area to let in less water.
1980 23' SeaCraft
