Old 03-07-2012, 11:24 AM
mrobertson mrobertson is offline
Originally Posted by sidelock View Post
mrobertson, how did you deal with the wet wood around the deck perimiter under the border of the original decking you left when you cut it ? and are those the original skins you glued back on the new plywood ?
I didn't really. I opened it up and let it dry out for a while. I did an entire deck replacement on a 23 and this is kind of a "budget" build. The wood around the edges seemed to be pretty dry after it was opened up and left alone for a week.
Yes - those are the original top skins i glued back in. I cut into the deck about 1/2" and pryed the skins up, leaving them in tact. Before putting them back down i made sure to grind the underside and sanded with a 40 grit paper.
