Old 03-11-2012, 06:54 PM
Originally Posted by SBD View Post
...Thank god I am almost done.
Amen to that, Sean!
I'm still on track for an initial launch next Saturday. Got lots of little stuff done over the past two weeks:
* Fresh anodes installed on outdrive and trim cylinders.
* Outdrive installed, trim sender and trim limit switch adjusted.
* Outdrive filled with fresh gear lube.
* Installed rigging tubes under the starboard gunnel for control cables and misc. wiring.
* Remote control installed, cables connected and adjusted.
* power trim and " trailer up" switch wired and tested.
* Ignition switch installed and wired to neutral safety switch.
* All gauges, including vacuum and Flo Scan connected and working.
* Installed switch panels at the helm.
* About 80% done with installation and wiring for the trim tab pump and controls, including Bennett's AC3000 Auto tab controller.
*Installed prop and fired up the engine and put it in gear to make sure the prop turns in the right direction. (It does. )
The end is near.
Dave
Blue Heron Boat Works
