  #25
Old 04-06-2012, 01:08 AM
Originally Posted by fg1 View Post
The last hard top we made was 2 layers of 17.08 on top, laminated off-axis, and 1 layer of 17.08 on the bottom. No matter what core you use, you're going to have to make compression sleeves for every bolt and penetration.
With only 1 layer of glass then sleeving would be a must. The top I pictured earlier weigh's less then 120# The bases of the piping are 3.5 inches diameter and there are 3/4 " diameter washers on the top. No dimples anywhere in the glass. If one decided to use balsa then I probably would agree that sleeving to prevent water intrusion would be a good idea. I dont think Balsa is a good idea on a roof especially when there are so many other good products out there....just saying...
