Re-reading the above message, I realized I forgot to make a small but significant point or two.
The power is comparatively low. Any impact will be cummulative. It's power is relative to the inverse square rule, which is; If you double the distance, the power is reduced by a factor of 4. (ex. At four feet the power is one fourth of what it is at 2 feet, etc.) So you can see that how close you are to the source matters a lot. Also, the duration of the exposure is obviously significant as well. The only real practicle threat is if you have part of your body in the beam's path for a signifcant period of time at fairly close range. I would think that to be standing in the beam's path while fishing or some other similar activity on a boat of size of a SeaCraft, there could be detectable changes. Also, the guy sitting at the flybridge while the radar is on will have damage.
Getting home is more important than getting there! Plan accordingly! Last edited by BigLew; 04-21-2012 at 07:27 AM. |
