Old 05-06-2012, 10:50 PM
You're running the same setback as I am with an even heavier motor, so you will definitely need a 4B prop to get some stern lift and maybe some sort of fin on the AV plate, for decent low speed planing.
I second that one. I am a big fan of the hydroshield skeg mounted fin. You can plant at slow speed, and you slowly settle the boat coming off plane, rather than a noticeable transition. I bought a Solas Amita 4 blade prop for stern lift, too. About $100 in aluminum, not sure if there is a SS version.
