Old 05-10-2012, 06:40 PM
Originally Posted by hiliner222 View Post
So you wrapped around and adhered to hull bottom. Didn't that make like a hump at the end of the bottom? or did you pre grind it out?
Had to grind all the gelcoat off and put in a notch where the 8 inch tab in was made.. When i was done i grinded down so it was flush with the rest of the boat. Used a long straight edge to make sure it was true to the rest of the hull.
