Old 05-12-2012, 11:17 PM
Scott,
Looks like you have room to cross your scupper drain lines before you run them out the transom! I think the gas tank support deck (and maybe the tank) have been replaced. The original tank support was 1/4" plywood.
Thats the front 4cyl 120 hp engine mount support, it's behind and abutts the tank. I't glassed with roven and fairly thick. The tank is fiberglass and need to be replaced as the ethenol fuel will break down the glass. I like your idea about tieing in the scuppers to one line if i even have scuppers. their so low at the watterline i may dump into bildge and let pump do it. I don't moore it, i trailer it so wont be a problem. If the deck was higher. I havent decided yet, still thinking on that one. But if i do i'll do the crossover for sure.
