Old 05-17-2012, 10:59 AM
cdavisdb cdavisdb is offline
Good deal. 7000 lbs works well for me. Looks like you will have to raise the bunks a bit to fit the 25. I modified my Owens by adding a 1x4, curved and raised another inch on the forward end to fit the curve of the hull. Fit the hull perfect, worked great after I played with it a little. Be sure to check the angle of the bunks to match the hull where they will touch. Also, the bunks should be under the strakes, where the stringer is. Looks like yours will be in just the right place.
Looks like you have torsion bars. If not, think about going to torsion bars when its time to respring.
