Old 06-02-2012, 04:48 PM
Here is the console when I got it
http://i22.photobucket.com/albums/b3...s/100_0851.jpg
It looks like it had plexi glass doors that spaned the console but I change it
I want to flush mount the electronics on the right side and have a "glove/storage area" on the left but the grab bar limits my choices.
Thinking I could do the plexi doors but just on the left side, I still have most of the teak so I would only need the bottom piece
Opinions???
I was also working on the trailer.
I eliminated the rear center roller and moved the bunks in so the it would support the hull and centered it also, I plan to get a piece that would protect the hulll with the rear cross member and attach it there.
Next I had already installed the battery switch and placed the batteries under the console and will finihed hooking up the batteries to the switch
I have an appointment to take the engine to have the lower unit worked on as it is leaking fluid around the prop shaft most likely the seals are bad
Then I plan to hook up at least one bilge pump and take it for a run just to see what happens.
