Old 06-11-2012, 02:00 PM
Originally Posted by pelican View Post
screws should be 10-32 fine thread...maching screws - not self tapping !
jb weld,or anything else will prove to be a bad choice...
Thanks for the feedback guys.
Pelican,
I have used "water weld" to effectively seal an aluminum oil pan hole and it has held 5 years or more but that is different. Obviously I'm a little leery that an epoxy would hold up in such a minimal surface area application.
I see your point and concur that threaded 10-32 screws would offer better holding power and be less subject to stripping the holes (which probably happens due to over-tightening). I can still do that on 4 out of 5 holes. But I ask why tanks rarely come threaded, and why virtually all sending units are shipped with stainless deep thread sheet metal screws (sharp but not self-tapping).
The over-size hole is my immediate concern. Repair or adapt are my only options. What's the better way to resolve this? Over-drill the sender or some form of patch?
Leaning toward over-drilling the sender as Normagain opined.
Thanks.
Old 06-11-2012, 05:44 PM
bilgerat bilgerat is offline
Helicoil, if they make one that small
Old 06-11-2012, 08:13 PM
pelican pelican is offline
Pelican,
Thanks.
after 20yrs in the marine biz - i've yet to see a fuel tank,the area for the sender,the holes,not to be tapped,10-32,the area is usually double thickness for the tank...
"self tapping" screws will not seal...the cheap fuel sending units-these usually come with 10-32 screws,with a sealer that squeezes out,when the screw is fully tightened...
me,personally,i wouldn't use any kind of sealing product on a fuel tank - ever !
Old 06-12-2012, 07:19 AM
Default not to beat a dead horse...
take a look at this picture,zoom in on the sender - pay attention to the screws - they're not the same all the way around - you should notice that...the owner of this boat,he did a similar thing as you're going to attempt.stripped threads,used a big self tapping screw-end result - take a look at the top of the tank,clearly it's "stained" around the sender - clearly leaking...
there's another way,to attempt repair - provided the tank's in good condition - if the threads pulled,odds are the tank's pretty old ...it appears you've had some problems with your fuel system...
Old 06-12-2012, 10:16 AM
I'm not seeing where he said he was going to use self tapping. He said it was tapped to size 12 with machine screws. If the sender has a rubber gasket (I'm not sure how they are set up but I think so) a larger sized proper screw should be fine. If not, and it uses gas proof sealant like Permatex whatever, again, should be no problem.
Old 06-12-2012, 07:55 PM
Only problem I've had with my fuel system was a chunk of what looked like silicone in my supply elbow. I presume that was from the previous owners attempt at sealing the sending unit.
Other than these over-sized holes my tank is in good condition.
I tried to re-tap them at 10-32 but they are simply too big. 12-24 will require me to re-drill the flange on the new sender. Don't know if a M5 size will work or not.
I was hoping to generate ideas but you kind of left me hangin' for your "repair" suggestion. Did you have an repair idea?
Bilgerat's helicoil idea is cool but it'll run me $40 for a kit and I'll be waiting 2 weeks to get it off some backorder.
I also thought about epoxying some pan-head screws to the inside of the tank but the thought of snapping the bond should I need to get in there again is another potential miss.
Any repair thoughts? I'm all ears...
