Old 06-17-2012, 04:11 PM
Now that's how a SeaCraft should sit in the water! I gather that you're satisfied with that motor! These boats don't need a lot of power if they're set up and balanced right. Curious to know how much your min planing speed changed and what your WOT rpm is with that load? Here's a great web site you should check out that will tell you optimum WOT rpm for your motor: http://www.etecownersgroup.com/post/...u-2011-5396435 Motor is at optimum height when the AV plate is completely out of water when you're up on plane and fully trimmed out for normal cruise.
If you haven't already done so, I'd strongly recommend you run only XD100 oil and have the dealer set the ECM for it. It's more expensive but you'll use less of it and the motor will build up a lot less carbon. My dealer buys it in bulk and I believe sells it at close to cost. Last gallon I bought was $35 a few months ago and it's good for 100-150 gallons of gas!
