  #29
Old 07-15-2012, 08:52 PM
Originally Posted by 3rdday View Post
captbone,
Thank you for your input and valuable insight and experience..
I hope it works ok, like I said the 300 v8 will be for experimenting and short term, if it does well i know the etec 300 will. In any case it wont be a big deal to reset for twins.
Im going to be adding knees to the stringers and transom and a longitudinal beam across the transom. I re cored the transom last year with composite, eglass biax and epoxy......
Its easy work as long as its not in the dead of summer- my only complaint is grinding glass in the summer.
EDIT+=Sorry for the thumbs down at the top of the post - meant for it to go at the end of"grinding glass in the summer"
Always thinking outside the curve...good for you. Called Monty and Gordon said you will be happy with the big E tec. Twins are a bit heavier depending on choices, but in the middle of the panel, may be happy, balanced, and neutral through the controls.
Cheers
Us
