nida core : basically made from recycled milk jugs,held with a light scrim bcking - this produt will NEVER hold a screw,or any othr kind of fastener - the fiberglass skin on both the top and the bottom will - however,i would never trust it...thru bolting and sleeving is the way to atach someting,when nidacore is used... there's a trick when working with aluminum or solid fiberglass - if you're gonna use a 1/4 - 20 machine screw,just drill a 3/16 hole,insert the screw,and send it home,it will "tap" either aluminum of solid fiberglass - ocean yacht used this method alot... no offense: nida core is a product i treat like kryptonite...here's what it looks like... i'm gonna guess the reason for the mix of core materials is due to what i stated concerning nidacore - not to second guess anyone,but,using a mix of cores - composite and wood is a little strange - normally,when using a composite,the core is removed in the area the fastener is going to be located,that area is filled with thickened epoxy,the epoxy will hold a screw...
