Old 08-11-2012, 08:32 PM
3rdday 3rdday is offline
Default Input
Thank You Gents, Much to consider, especially the trim range/Angle.
Yes the Yamaha 350 might, but its allot heavier.
I was just going to experiment with this for the purpose of running a single.
If I can't get decent performance Ill probably go with twin etec 175 or twin 200 etec.
It's nothing for me to unblolt, do some composite work, and re-bracket , childsplay!!
I'll would think the operating angle of the engine would not work at the angle the bracket appears to be in the second photo. I don't think the trim portion would go that far and compensate for that angle. Probably be up into the "tilt" area, which would be unsafe to operate at speeds above 5 mph.
I'll bet a Yamaha 350hp V8 would do the job fine...
Old 08-12-2012, 10:22 AM
Much to consider indeed.
Denny has shown that you can mount an engine much higher than the norm on a VDH hull w/ a
large flotation bracket.
Carl opined, why not make a bracket follow the running surface of the hull as already designed?
How much travel does the jack plate allow?
I saw the new Ocean Master 27 cc hybrid at the show 3 yrs. ago. Rigged with twin 150 e tecs.
Mark said it would hit 50 light and plane off on one engine.
Please post audio of the V8,
GFS
Old 08-12-2012, 11:08 AM
Hey Sandy, I've got a friend who has one of those V-8 350 hp Yamahas. At "full song" it makes a very loud fuel sucking noise....very loud. I'm not sure a 3/8" fuel line is big enough.
Old 08-12-2012, 03:00 PM
Default Evinrude V8 MUSIC!!!!
Here Ya go Sandman.
Music to your ears!!!! and Mine too.
http://www.youtube.com/watch?v=GcrpMbSXWF8
Old 08-14-2012, 07:15 PM
Here Ya go Sandman.
How can you not love that? Ohh, it smokes. Ohh, it`s loud. Ohh, it hurts my ears.
Crank it up and rip the knob off!
Still mixin` oil,
GFS
Old 08-14-2012, 10:33 PM
2 stroke V8....doesn't get any better than that!! Awesome power to weight ratio...
Old 08-18-2012, 10:29 PM
Default Prop
Thanks again everyone-
Re Prop; I read about a 30' with a 300hp v8 looper that the 4 blades robbed him of power,too much stern lift robbed him of forward motion, Ill probably start with a 3 blade first, and see what happens. not that I lost 900 lbs, and the thought is the stern will be lighter- Not sure if the 36" setback bracket+ the 6" Jack Plate will affect/compensate balance.
With that kind of total set back I should be in really clean water.
Old 09-20-2012, 03:08 PM
captbone captbone is offline
Hows it going?
