Old 08-27-2012, 12:32 PM
Well water does always seek level. Have you thought about plumbing extra drains with check valves to the motorwell and adding drains to the transom at the motorwell and leaving your current configuration intact. If the depth of the inside of the motorwell and floor make sense I'd be leaning that direction myself. Then again without standing in your boat in the water and with a tape measurer I could be completely wrong.
Old 08-27-2012, 07:21 PM
littletunny littletunny is offline
Ok guys. Found something today at HD that may work. I will shave the lip down to the taper.
looking from the center of the boat to the starboard side at the non working horizontal scupper:
Same scupper looking aft.
The new drain will go directly under the existing drain:
The pad at the stern where the new thru hull will go:
