i use interprotect 2000e - nothing else
you need 2 colors - grey and white this assures a full coverage - you want that coating approx 10mil thick - use a matchbook cover as a guide prep: clean with acetone - scuff sand,chemically etch prime,them coat it.. nothing will properly adhere to aluminum,without a chemical etch prime
Sorry Line X. |
![]() why ? seriously,why ? epoxy products are waterproof - meaning,the aluminum is completley isolated from any moisture - read that as corrosion now,i've seen and read of some backyard guys actually believing,if they fill the pinholes in a corroded tank,with marine tex,and then,wrap that corroded tank with fiberglass matting - using a polyester resin - common sense would tell us,this is a real bad idea,yes ? i've seen a fuel tank coated with rhino liner - that coating failed,and failed miseribly... sometimes,it's best not to try and reinvent the wheel - it's round and it rolls...
A very well respected builder uses something else. And then we can talk about MMC. The best thing about this site is the folks who care, GFS |
just because a "well respected builder" uses it,doesn't make it a good idea,or the preferred method - i've seen plenty of "well respected builders" do some really stupid things - proline is a good example,i replaced a transom in an older proline - the core was CDX plywood stapled together,and pieced,stringers were the same material - not good huh ? grady white is another - their cockpit deck hatches are supported by the fuel tanks - against codes - is that a good idea ? is that a good method ? their scuppers are under the waterline - depending on the load in the boat - no positive shut off - again,ABYC codes state that's wrong -is that a good method ? get the point here ? guys that are "in the buisness",like ol' don herman,and myself - see things in a different way than guys who are doing pojects in their backyards - don't read any disrespect into that,if you guys make a mistake,no big deal,you're gonna do it again,a follow a better procedure - "in the buisness",it's a little different - get the point ? yep,i care - i hate to see people make a dumb move,i give "the voice of experience" - i try and save you a step - the "step" being,making a bad decision,that's gonna cause a problem down the line... there's a great movie - pulp fiction - great line "a sewer rat may taste like pumpkin pie,i wouldn't know,'cause i would never eat the filthy motha *@#*er" i'm open minded,but not that open minded...
Colors on display. Richard. You Suck. Go away please. GFS |
Quotable. |
