After having 2 inboards I would recommend not cutting corners.
Your best converting to a chevy power and carb to keep it simple. Raw water coole will be simple and cheap and should last a while with only riser and manifold changes every 5 years. Here is a good site to get some estimated costs. http://www.marineexhaustmanifolds.com/ or http://bpi.ebasicpower.com/index.php You could find a rebuilt or used 318 but you may end up in the same boat if you run into issues again. Spending more $$ and time at the dock vs out on the water. Depending on the HP you had now you may be able to go down to the 4.3 v6 Chevy.
Glen 1996 23ft Contender 08 Yamaha 250 HPDI 1965 13ft Cacci craft skiff with 20 Hp tohatsu 4 stroke 1992 20ft Shamrock Predator (Hard Top) 351 FWC PCM Repower SOLD First boat: 1988 17Ft Shamrock Open 3.0 Mercruiser RWC 140hp Traded |
Display Modes | |
