Old 11-24-2012, 12:15 PM
Default Fuel tank question
Alright. The above pictures are of my 20 SF. The fuel tank originally was under the console. This is the same tank pictured but rotated 90 degrees and slipped between the stringers. The bottom of the tank is at least 1 inch from touching the center stringer. It is tight to the stringers on the sides. I could probably force it Down and reconfigure the fuel fill to be back by the supply to the engine. The fill would then go through the console. Are there any concerns about it being such a tight fit between the side stringers. I know a lot of you like to let it breath as much as possible. There is some room, just very minimal. This would save me some decent money if I could just reuse the tank. Also in the pics you can see that I just glassed in the raised stringers. Thanks for any help. Any concerns at all??? Thank you.
Elijah
