Old 12-03-2012, 10:06 AM
bigeasy1 bigeasy1 is offline
Originally Posted by ScottM View Post
I'm sure Chris will chime in, but I don't think his performance with the big block is that much better than a small block. He's got it hitched to a Bravo drive and needs massive Kiekhafer trim tabs to keep her balanced. The biggest down side I've personally witnessed in his boat, and I'm sure he'll concur, is water through the scuppers due to that extra weight. With a couple guys in the back at rest, you've got a good 1" of seawater on deck. Typically I concur with "there's no substitute for cubic inches", but in the case of a 23, it seems to work against you.
The 350 just seems made for the 23; go for that and you'll be more than happy.
Yeah, I love the 350 and no doubt that the extra weight of a 454 would be a factor with the thru-deck scuppers(I hate them).
I have that problem with the extra weight from the Yamaha kicker(105 lbs),and the four down riggers,each with 15lb weights,two off the stern,and two off the rear sides.
They drain fine when we are sitting forward or amidships,but if we have two of us standing in the rear,as when fighting and netting a fish,water pours in through them.It's not bad on a hot summer day,but in the spring with water temps in the high 30's forget about wearing sneakers.
I made a version of the "Vortex" out of some 2" long pieces of type m copper tube and the finger from a latex glove.Most of the time they work pretty well."most of the time"not all the time.
All this,just for a boat ride
