Welcome to CSC Wally! There seem to be Sceptre 20's coming out of the woodwork lately, which is surprising, since they are one of the rarest model SeaCrafts. I personally like that layout very well because the bow access is nearly as good as a CC, but you have a huge cockpit without that cc taking up all the space! Strick's current restoration should give you a lot of ideas for it.
Regarding the transom and deck, my '72 Seafari is all original, with NO soft spots anywhere in the deck. It's 1/2" balsa core, except for 3/4" plywood where the seat pedestals are mounted. Don Herman, who closed in my transom and installed one of his brackets, said it was one of the driest transom's he'd ever seen on a boat that old. My point is that if it was well taken care of and all holes properly sealed, the transom isn't necessarily soft just because it's old! I believe there are 2 major things that kill transoms in the 20, besides improperly sealed holes. One transom leak source, which I've seen on '72 and earlier models, was the baitwell inlet/exit under the port stern seat. Carl Moesly came up with a very clever design consisting of a 4" diameter Phye plate/cup right at the waterline inside the baitwell. There were a bunch of 1/8" holes through the cup and transom that let water run in and out, with a big 3/8" hole in the center through which water entered via a piece of 3/8" tubing that ran down through a bracket and extended just below the hull. The tubing was cut off at a 45 degree angle and provided a very strong stream of water into the bait well when you're up on plane. The screw-in plate kept the water out when you didn't want to use the bait well. The only problem was that the cup was installed thru the core and bonded to the outer skin with polyester putty. That stuff is fairly brittle and if it cracks it will let water into the transom core. I think Moesly ('68-'69 models) put the sealing plate on the outside which would have kept the transom dry when the baitwell was not in use, but Potter put it inside the baitwell, so the core could be exposed to water all the time. Mine had started to leak but my boat was only 3 years old when I got it, so I caught it before it got too bad, dried everything out with alcohol and resealed everything with epoxy. Ran it that way for about 25 years with no further problems before installing the bracket. Don filled the hole with a Coosa plug and glassed over it, since one of the bracket bolts went right through that area. I think Potter eliminated the under seat baitwell starting in about '73, so that '74 model probably doesn't have it. The other area that can let water into the transom is the gap between the inner liner and transom core under the aluminum trim in the engine cutout. This was also sealed with the brittle polyester putty which could crack and eventually let water into the core. The dealer I bought my boat from warned me about this and said that on all the new boats they sold, they removed the trim, routed out that brittle putty, and resealed it with polysulfide sealant (Life Caulk), which remains flexible and won't leak. I did the same before installing a new motor on the boat and I think that's what kept the transom dry all these years. The 20' hull is pretty much bullet proof with the all glass stringers. The laminate schedule is similar to a 25' Bertram, so they are seriously overbuilt! There is a wood 2x4 in the keelson, but there is so much glass over it that even if it rotted out, it wouldn't matter since all the stress in a beam like that is in the outer fibers anyway. The only problem areas are the brass tubes in the vertical scuppers and forward fish box, which tend to corrode over time and start to leak, but they are easily replaced. There are a number of threads you can find by searching on "leaking scuppers" that show how to replace them. I believe Potter raised the cockpit sole in about '73 or '74 to improve self bailing capability, but if you repower, I'd stay with a light 2-stroke under 400 lbs to insure the boat remains self bailing at the dock. Those old cross-flow 150 GT's were very simple and strong (but thirsty!) motors, but the modern DI 2-strokes are still relatively light, with fuel consumption numbers that can match or even beat a 4-stroke. The VDH hull is very efficient and will easily run over 35 mph with 115 hp if you don't load it too heavy. Sounds like you might have found a pretty solid boat! You might want to check on the fuel tank condition, which is very easy to do on a Sceptre or Seafari because of the removable hatch. I pulled the tank on mine when I got it and found that someone had dropped a brass nut in the bilge before the tank was installed, and there was some galvanic corrosion starting there, but I was able to clean it up, patch it and paint the tank. I'm still running the original tank. They weren't foamed in at the factory and tend to last a long time if installed properly. Good luck and keep us posted on what you find! There is a wealth of knowledge on this site if you have any other questions.
Display Modes | |
