I spent many years managing marinas in the south. I echo that the previous paint is probably peeling/flaking off because of poor prep. The other reason it can flake of if it was an ablative paint that spent a lot of time in the air before being initially immersed - like months.
Regardless of the cause of the problem, the old paint has to be removed to get new paint to adhere properly, AND it needs a good barrier coat if you're going to keep the boat in the water using an ablative paint like Interlux Micron or Petit Horizons. If you're going to use a hard bottom paint like Interlux Ultra or Petit Trinidad, simply removing the old paint and sanding the bare bottom with 80-120 grit sandpaper will provide you with excellent adhesion and durability. If you intend to keep the boat on a trailer, you need a hard bottom paint that uses biocide leaching for antifouling, as well as being resistant to wearing away from launching and reloading onto the trailer.
Common Sense is learning from your mistakes. Wisdom is learning from the other guy's mistakes. Fr. Frank says: Jesus liked fishing, too. He even walked on water to get to the boat! Currently without a SeaCraft ![]() (2) Pompano 12' fishing kayaks '73 Cobia 18' prototype "Casting Skiff", 70hp Mercury Last edited by Fr. Frank; 03-14-2013 at 08:37 AM. Reason: spelling |
Display Modes | |
