Old 03-26-2013, 07:44 AM
martin martin is offline
Originally Posted by Entourage View Post
Wow all epoxy cha ching $$$$$$$ lol. Hell that's even better but yeah 1/2 or 3/8 would be fine on the trawl. Keep us posted, that's going to be a strong transom.
Yes i know,,, but it is what i had started with. The layup from start to finish has been all epoxy.. . I do not wnat any problems with delamination. Or water intrusion, blisters.. More less peice of mind... I never had much luck putting polyester over epoxy...plus i plan on leaving boat in water for a few days at a time.. Twin outboards on a alum bracket mounted.. I do not want to derig and fix transom. Also i cut the outerskin off therefore inhm weaken the hull ... All these factors played in my head and well i optd for the epoxy... Alot more expesive. But after said and done i should not have to do again..
Old 03-26-2013, 11:56 AM
Very much agreed
Old 03-26-2013, 10:23 PM
Default transom
ground off the excess. And cleaning up the skin I should have done this when the skin was just pulled off and the wood was wet.. Would have been easier.. Boy I wish I had a belt sander..
Old 03-27-2013, 05:31 AM
hermco hermco is offline
Do you mean an air chisel with a wide blade?
Old 03-27-2013, 06:54 AM
I saw something new at lowes that would work well for this. It was a wide scraper blade on a chisel that would fit a standard sawzall. They were only like $10 and it looked like it would work well for something similar to what you had to do.
Old 03-27-2013, 07:35 AM
I use my dewault 7 inch buffer/grinder with a 16 grit pad on it with the variable speed all the way up. Actually works better when the wood has dried.
