Old 04-09-2013, 10:12 AM
ct9amr ct9amr is offline
I would first check the weight of what your pulling out vs what you are replacing it with.
The diesels tend to be heavier to just make sure you are not adding too much more weight.
As for the comparison you will want to look at the TQ curves for both and see what RPM will work best.
Prop choice will also be a big player on what the setup is capable of.
Glen
Old 04-09-2013, 10:19 AM
Harper Harper is offline
Thanks. The engine weight along with the required transmission will be heavier in the 200-225lb range.
