Old 04-10-2013, 09:26 PM
Drain holes go right through the balsa. A few of mine had allowed water into the balsa core, with some modest rot. Surprisingly(to me) the deck seemed completely solid from above, lots of glass, I guess. I filled the rotted out balsa with epoxy (it wasn't all that much), filled the holes with epoxy paste and redrilled them. Worked OK, but the hole diameter is a bit small now. Holes at least as big as original, or bigger would be better. One problem with the arrangement, the water drops from the holes straight into the bilge, a loong way from the stern access. Pretty much any solids that drop through with the water are going to be trapped in the hull. Give it time and that will be a lot of crud. Several owners have reported drainage problems, maybe related to inaccessible crud. Screens on the drains would be a good idea.
This is why the deck is stiff with mushy core. This is the piece of deck cut out for starter access in the engine bay by the previous installer. About 0.300" (5/16") laminate, then a 1/2" core of balsa. Wow. This is a 1971, pre OPEC oil embargo. Maybe later boats have less glass and resin?
Old 04-11-2013, 08:41 AM
...About 0.300" (5/16") laminate, then a 1/2" core of balsa. Wow. This is a 1971, pre OPEC oil embargo. Maybe later boats have less glass and resin?
Mine is a '72 and looks about the same. Still pre-embargo, though...
Just a fun fact - 49 of the 80 25' Seafaris were made in '71 and'72.
Blue Heron Boat Works
